Thread Like Summary
Pitcrew
Total Likes: 2
by Pitcrew
Pitcrew
I’ve just finished off restoring my 38 Master Deluxe ready for the road. After refilling with antifreeze and running up to temperature I found water dripping down from the bell housing. After removing the bottom inspection cover, it looks to be coming from behind the flywheel and suspect the freeze plug has a corrosion hole in it and leaking out. Can I replace this without removing the engine? What is required? Thanks
Liked Replies
by Blue 50 convert
Blue 50 convert
Yes, split the "U" joint so you can remove the tranny. Repair manual shows how.
1 member likes this
by tonyw
tonyw
you will need to remove the engine or gearbox/bellhousing as that plug is partly covered by the bell housing.
1 member likes this
