Thread Like Summary
Clement, JohnS
Total Likes: 4
by JohnS
JohnS
I just bought a ‘51 Styleline Special with no oil filter or turn signals.
Safety dictates I address the turn signals first. I don’t think most current drivers recognize the hand signals I learned 110 years ago.
What is the best route to getting a “kit” if possible, to add this feature?
Thanks for any wisdom.
Liked Replies
by Chev Nut
Chev Nut
Try the FillingStation and Chevs of the 40's for the directional signals.
If it were mine I would not bother installing an oil filter. Not really necessay unless you travel thru dust storms.
2 members like this
by WildernessTruck
WildernessTruck
If you look at any of the model A catalogs, you will find complete 6 volt &12 volt turn signal kits.... I found them also for sale on Ebay ... just put 6 vt turn signal in the search box.... be sure to buy 6 vt LED bulbs for brighter turn signals and a 6 vt electronic flasher for the LED bulbs... all available in the model A catalogs or Ebay
1 member likes this
by Mr87Monty
Mr87Monty
I purchase on that was for 12v but per its instructions only the indicator bulb and the flasher had to be changed to make it 6v. It worked well and was easy to wire in. Part of the easy wiring for me was that we were in the process of rewiring the car anyways.
I highly suggest sitting in the car and moving it around on the column to find where you want it. I put mine in reach but the indicator bulb is generally blocked by my hand when driving.
1 member likes this
