Today I was driving my 1939 for a longer drive in the countryside. After 45 mins drive I heard a high frequent whistling sound, like a small bird. I stopped the car and felt some smell and I found the rear left side wheel hub was very hot, I could hardly touch it. I waited some minutes to let it cool down. I drove slowly 5 more minutes to my destination.Then I realised the brake pedal was lover than normal, and I had to pump it a couple of times. Then I parked the car for many hours..
On my return in the evening, the brake pedal movement was Ok. No more «bird sound», and no overheating. I stopped the car several times to check the temperature of the wheel. On my last check at home, I found a minor heating again. Something is wrong in there. I have to check out this and solve it. What is the most likely reason, the wheel bearing overheating or some brake failure?
