It could be many things but if I don't use my 39 for an extended period of time the wheel cylinders will start to lock up from moisture contaminated brake fluid. After replacing the wheel cylinders I have been trying to drive it at least every two weeks and it seems to have helped.
I think you will need to remove the wheel and drum and inspect the wheel cylinder. Of course if it is gunked up all of them will need rebuilding.
