Thread Like Summary
Clement
Total Likes: 1
#482146 05/29/2023 8:13 PM
by carlk
carlk
Drove my 32 cabriolet in Memorial Day parade today and everything seemed fine until I was pulling into driveway when I depressed clutch pedal it went to the floor with no tension .Don't remember if I depressed the pedal and got it out of gear or got it out of gear without the clutch pedal. Anyway now it goes to floor with no tension and so it can not be shifted. It does pop back up again when foot is removed Any suggestions would be greatly appreciated
Carl K
Liked Replies
by Rusty 37 Master
Rusty 37 Master
The shop manual should have the information you need to remove the transmission so you can get access to the clutch area.
This is one of those "while you are this far in" projects. This would be a good time to inspect and replace the clutch if needed.
My recommendation is to get everything disassembled and then determine what parts or repairs are needed.
1 member likes this
