big D Offline OP
Rear axle-pass.car axle housing seat and cap, rear spring,right part #351634. and rear spring left part #345149. These # are in the Master parts price list for 1929-1932 . The parts I took out of my car have these # on them #351632 and #345145.also one of them is about 1/2" taller than the other. Are these in my car wrong, what might they belong to, and where might I find the right ones. Thanks in advance for your help.
Your parts are correct....those are casting numbers on the parts and the casting numbers are usually slightly different than the part numbers. Also, one spring saddle is supposed to be higher than the other. If you look closely at them you will see that one saddle has a raised base cast onto it and the other doesn't.
:) wink :grin:
big D Offline OP
Thanks Junkyard Dog. One more question. Doesn't this make the car sit lopsided .
This is a factory design and one side was supposed to be slightly higher than the other when the car was new.
:) wink :grin:
big D Offline OP
Thanks Junkyard Dog. Got one more question. Differential Carrier and Propeller Shaft Housing. I have two of these. One is stamped #1760308 and the other is stamped #5079. Which of these is correct for the 29. Thanks again for your help.
I don't have anything that lists those numbers.
:( :cry: sick
