MrMack Offline OP
Does anyone have a circuit diagram of the 3 post flasher?
It has 3 positions. The best I can read on the small circuit diagram in the shop manual looks to me that:
(X) goes to power (6 vdc)
(L) goes to the turn signal switch
(P) goes to one side of each directional switch indicator bulb.
Is this (P) position the ground terminal? it looks like maybe it could be the current return to ground, or what is it's purpose?
Hey Mack, Sent you an email.
Cheers!
MrMack Offline OP
Thanks KHARDY!
