#99681 04/20/07 10:43 PM
In down town Emeryville California there is an old brick building that has been modernized into an office building. On two sides of the building are signs with the Fisher logo on them that say "Fisher Body Building" on them. Does any one know if this was the Fisher location that supported the Oakland plant years ago?
Matt M
Matt,
Can you take a picture and post it here the next time you're in the area?
OIL CAN DAN
FISHER BODY PLANTS SHORT HISTORY
1. Fisher Body Company Plant No. 1 [later called No. 2], 1368 St. Antoine Street & Piquette Street, Detroit, Michigan. Built as 5 story open body plant in 1908 and added top 6 story in 1914.
2. Fisher Body Closed Body Company Plant No. 2, [later called No. 4] Piquete & Oakland Ave, Detroit, Michigan. Fisher Closed Body Co. opened 1912 for building closed bodies.
3. Fisher Body Corporation of Canada, Plant #1, St. Luke & Edna Street, Walkerville, Ontario. Established April 1912. The company, though originally formed for the manufacture of open automobile bodies for the Cana-dian built Ford, started produceing in 1916 open bodies for such companies as Chalmers, E-M-F and Studebaker. The size of the plant was doubled in 1919 and in 1920 it began making passenger car bodies for General Motors. The plant was closed in early 1923 when the Ford open body contract was canceled. Fisher, after leasing it to Chrysler in 1927, sold it to Studebaker in 1932.
4. Fisher Body Corp. Plant No. 18, 261 West End Ave at West Fort St, Detroit, Michigan. Built in 1917 as its Aeroplane Division plant and built some 2000 aircraft. The six-story structure designed by Albert Kahn was made with reinforced concrete, with Fisher Body pur-chased plant from the government in early 1919 and for several year Plant No. 18 was the largest body plant in the world. By 1931, the plant was building bodies for Cadil-lac when the Fleetwood opeation was relocated here and Plant 18 was named the Fleetwood Plant. The Fleetwood Plant was closed in 1984 and in 1993 was demolished.
5. Fisher Body Corporation of Canada, Plant #2, St. Luke & Edna Street, Walkerville, Ontario. This 5 story plant was built on the east side of St. Luke Road at the NE cornor of Charles St. Opened in Spring of 1920 to build close bodies only for Ford, Essex, Oldsmobiles, and McLaughlins. Plant closed in Spring of 1924 when Ford closed body contract was not renewed. It later became a part of General Motors and its premises were used for the assembly of GMC truck and bus bodies from 1928 to 1932. Plant was sold to Packard in 1934,
6. Fisher Body Corp. Plant No. 21, corner of Hastings and Piquette Ave, just east of Woodward Blvd., Detroit, Michigan. This plant was design by Albert Kahn in 1919 and used up to 1925 to produced bodies for Buick and Cadillac. After Buick bodies operations moved to Flint in 1926, it continued to produce Cadillac bodies until be-coming an engineering facility beween 1930 and 1956. The Cadillac limousine bodies were then built there until at least until 1974.
7. Fisher Body Ohio Company, Coit Road, Cleveland, Ohio. Incorporated in 1920 for $10 million to build 5 story $350,000 Fisher Body Plant with 1,500,000 sq ft opened in 1921 as the largest body plant in the world to supplied the Chandler bodies. It built the first Chevrolet Sedan body the night before Thanksgiving, 1921. Over the years the Cleveland plant was used to build the low pro-duction bodies like the 1928 Chevrolet Convertible [blank plant code] the 55-57 Nomad, and the Cadillac Eldorados. It was a metal fabrication plant when closed in August 1983.
8. Fisher Body Corporation of Canada, Plant #3, St. Luke & Edna Street, Walkerville, Ontario. Purchased the Chalmers assembly plant, that was opened in 1916, on the west side of Plant #1 in early 1922 to build closed bodies for the non Ford market. Plant closed when lost the last of the Ford closed body business ended in mid 1924. GMT Dept Plant #3 from 1931 to 1937 that assembled HD Chevrolet, Maple Leaf, and GMC Trucks.
9. Fisher Body Corp of St Louis, Union & Natural Bridge Blvd, St Louis, Missouri, open 1922 to build Chevrolet & Buick closed bodies. Plant changed to GMAD in 1971 and was merged into the GMAD Assem-bly Plant. Converted to a GM Truck Plant and closed in 1992? Plant sold to Clark Properties who is developing into the Union Seventy Center.
10. Fisher Body Corp, No. 1, Pontiac, Michigan. GM purchased the O.J, Beaudette Co. in 1922 to build Fisher Bodies for Oakland.
11. Fisher Body Corp. of St Louis, Janesville, Wisconsin, built adjacent to Chevrolet assembly plant in 1923. Plant Code #J. Changed to GMAD November 4, 1968, and was merged under the GMAD Assembly Plant. In ? converted to a GM Truck Plant.
12. Fisher Body Corp. Buffalo Plant, built adjacent to Chevrolet assembly plant in 1923 Plant Code #B, Car production stopped 1941
13. Fisher Body Corp, Norwood, Ohio, Built adjacent to Chevrolet assembly plant in 1923. Plant Code #N, later #NOR. It changed to GMAD 1971 and was merged into the GMAD Assembly Plant.
14. Fisher Body Corp. No. 2, Flint, Michigan, Chevrolet Ave. Started 1923 car production stopped 1942, Chevrolet Flint Manufacturing Plant 2A. Closed?
15. Fisher Body Corp of St Louis, Oakland, 69th and Foothill Blvd, Oakland, California, started paint and trim operations in 1923, with full Chevrolet body assembly in 1924. Plant Code # O, closed at end of 1963 models. Last car was a Chevy II SS # 3203600. The Oakland plant was replaced by the BOP Fremont Assembly Plant that built first 1964 car in June 1963.
16. Fisher Body Corp, Building 26, Olds Ave. & Division St, Lansing, Michigan. Started assembing closed bodies in late 1923 for the 1924 models in building 26 and over the next few years expanded its facilities west up to Logan St. to the west. After Fisher Body moved out to the Verlinden Ave plant in 1935, Olds used these facilities.
17. Fisher Body Corp, Tarrytown Plant, opened in 1925, sharing a 3 story building with Chevrolet. Plant Code #T. Changed to GMAD in December 1968 and was merged into the GMAD Assembly Plant. [One of 22 GMAD assembly plants in the US]. Last truck built April ?; last car February 3, 1989; last APV Van June 28, 1996. Plant was demolished for redevelopment industrial park.
18. Fleetwood Metal Body Company, Fleetwood, Pa. Company was started in 1909, with the Fisher Body Corp. purchasing the company in 1925. Fisher Body mostly closed down this Pa. plant in 1931 and moved the rest of its operations to Detroit to the Fisher Body Plant 18.
19. Fisher Body Corp. No. 1, Flint, 1926 S. Saginaw St. Mich. This ex-Durant Motors plant purchased for $4 million in 1926. Built Buick bodies starting in November 1926, and up to when plant closed in 1992?
20. Fisher Body Corp. Atlanta, Lakewood, Georgia, Open April 1928, Chevrolet Plant Code #A First GM plant to stage a sit down strike on November 19, 1936. Changed to GMAD in December 1968, and was merged into the GMAD Assembly Plant.
21. Fisher Body Corp. Kansas City, Leeds, Missouri. Opened January 1929, attached to Chevrolet Assembly Plant, Plant Code #K, Changed to GMAD in 1968 and was merged under the GMAD Leeds Assembly Plant.
22. Fisher Body Corp., Baltimore, Maryland, Opened adjacent to Chevrolet assembly plant in 1935. Plant Code #B. Changed to GMAD 1968 and was merged into the GMAD Assembly Plant.
23. Fisher Body Division Pontiac Assembly Plant In 1935, this Fisher Body Plant just east of Baldwin Road was completed. An overpass was built to connect the body plant to the Pontiac assembly plant. Plant was closed in 1988 with end of the Fiero production.
24. Fisher Body Corp, 401 Verlinden Ave, Lansing, Michigan. Plant was built in 1921 by Durant Motor Car Co. to assembly the Durant car. GM purchased plant in 1935 to build Oldsmobile bodies. Plant Code #L. Name changed to B-O-C, 1984, Lansing Assembly Division LAD/ SCG, 1992, then 1996 Small Car Group-Lansing Operations. NOA-North America. Today builds the GrandAm bodies.
25. Fisher Body Division, Southgate Plant, started 1936 adjacent BOP assembly plant. Changed to GMAD 1965 and merged into the assembly plant.
26. Fisher Body Division, Linden Plant, started 1937 adjacent BOP assembly plant. Changed to GMAD 1965 and merged into the assembly plant.
27. Fisher Body Division, Doraville Plant, started 1945 adjacent BOP assembly plant. Changed to GMAD 1965 and merged into the assembly plant.
28. Fisher Body Division, Kansas City Plant, Fairfax, Kansas. Started 1946 adjacent BOP assembly plant. Changed to GMAD 1965 and merged into the assembly plant.
29. Fisher Body Plant Flint No. 2, Van Slyke Road, Flint, Michigan, open in July 1947 adjacent to the Chevrolet assembly plant. Plant Code #F, last car built was a 1970 Monte Carlo, then converted into the Flint Truck Assembly Plant in 1970.
30. Fisher Body Division Plant, Los Angeles, Opened 1947 with Plant Code #L, attached to Chevrolet Plant. Changed to GMAD in 1968 and was merged into the Assembly Plant.
31. Fisher Body Division, Framingham, Mass, opened 1949 adjacent to BOP and later Chevrolett assembly plant, Plant Code #BF, G, Changed to GMAD 1965 and was merged into the assembly plant.
32. Fisher Body Division, Wilmington Plant, started 1949 adjacent BOP assembly plant. Changed to GMAD 1965 and merged into the assembly plant.
33. Fisher Body Division, Arlington Plant, started 1954 adjacent BOP assembly plant. Changed to GMAD 1965 and merged into the assembly plant.
34. Fisher Body Division Plant, Ypsilanti, Michigan. Opened 1959? Next to the Chevrolet assembly plant. Changed to GMAD 1971 and was merged into the Assembly Plant.
35. Fisher Body Division, Fremont Plant, started 1963 adjacent assembly plant. Changed to GMAD 1965 and merged into the assembly plant.
36. Fisher Body Division Plant, Lordstown, Ohio Opened April 1966 attached to Chevrolet plant Changed to GMAD in 1971 and was merged into Assembly Plant.
Author: Chevrolet and British Chevrolet Buses, 1929-32
Deputy Editor: VINTAGE ROADSCENE
http://www.ianallanmagazines.com/vintage.php
Great information; thank you for taking the time and trouble to post it.
The building that housed plant #18 in Fleetwood, Pa. still exist and you can make out the old name painted on the end of the Building.
Ya got to drive'em
Thanks to Ken Kaufmann please!
What a great amount of information. I did not see an address in Emeryville only one in Oakland. I am going to be there tomorrow and will take a picture of the building and get an address. Thanks all for your information.
Matt M
OK I have pictures but I don't see how to post them. HELP!!!!!
Matt M
