I could use some help. I need some good photos showing the front fenders and splash apron on a 1933 master. They would need to be taken from the front and from a couple of angles. I need as much detail as possible where the splash apron attaches to the fenders. My car had been hit in the front at one time and whoever repaired it must of had stock in "Bondo". After removing several pounds of putty I was down to the crumpled metal. I can repair the damage but need an example of the correct shapes to draw from. I have slow dialup so mail would be better option. You can e-mail me and I will send return with address.
jo_gindlesperger@prodialup.net
Thanks,
Spun Rod
