Ok now I have a real concern.
I noticed the other day after I started my 31 coup up it had a inconsistent Clunking noise at idle? :eek:
It wasn't steady and it seemed to disappear once I gave it some gas or while driving? When I got home I was backing it up and I think I could hear it again slightly. The car seems to run OK.
I pulled it in the garage and got out the famous noise identifier (Broom stick). I placed it on both sides of the head and block and could only hear the valves clicking away. I could not hear it through the stick anywhere. I finally did transmit the noise when I placed the stick on the Intake manifold just above the carb.
I checked the valve springs, didn't see any of them broken. Guess I better open up the oil pan next to inspect in there. :(
I had it opened up when I first got the car last year. It doesn't have any sims left but the clearances on one I check was about .001 or .002. So i put it back together.
I confirmed oil flow to the valves I had a good return flow. I put a new gear driven oil pump on last year when I got the car. I do not know how to confirm the oil lines in the block for flow!
Any ideas from the discription I gave on my possible problem /s??????
Puzzled / concerned
...Shocks
