Posts: 762 |
What is the trick to bolting the u joint back together with out the special tool? Having a heck of a time any tips or tricks would be of great help.
THANKS
Hi Tims37, This may be the long way around, but until I am proficient with Chevy Chat II, this is the only way I know how to do it. Click on the link below and then scroll down to entry 89919, 16 Mar 03, and within that page scroll further down until you find the discussion about U-Joints. "School is in Session"
Posts: 988 |
Make your own special tool; it is just a thick wire two pronged fork with a loop at the handle. Use a rubber band or chain thru the loop to tension it to the gear shift lever. The fork prongs go behind the U joint front plate and holds it place until you get the bolts started.
I have the tool but the last time I held the ring in place with a vise grip if I remeber correctly.
Posts: 988 |
I never remember where my vise grips are! So I use what ever is handy.
Posts: 762 |
Goter Done. I used the wire trick. Thanks for the help
Posts: 1,050 |
I find four letter words help !!
-BowTie Bob
Posts: 762 |
Yes there was a few of those flying I think a couple of the naighbors even brought the kids inside.
Posts: 619 |
Isnt it great how a few choice words, and couple of flying wrenches solve even the stickiest of problems
Posts: 11,162 |
