Posts: 9 |
I have just run into a problem with my door glass frames. Apparently the general produced an early and late 49 with different vent frames where they meet the door glass, mine are square cut and all of the replacement window frames I have found are angle cut and 1/8 inch short, they will not work. Has anyone else had this problem ?
Thanks, The Greasemonkey
Mr.Grease, Are you refering to the metal/chrome frame around the vent window or the roll down side window?
Posts: 9 |
I am talking about the frame around the roll up window. the difference is where it matchs up to the vent window frame at the top.
