#98477 03/30/07 09:50 PM
I am building a 37 coupe from a pile of parts and the frame was chopped off in front just behind fire wall. I bought a front frame section but seam to be missing about a foot. can anyone measure a frame and give me some numbers? I plan on using square tube and have some frame chunks to cover the tube, just don't know how much I am missing
I don't know if it's the same as a 37 but my 38s wheel base is 112 1/4".
The passenger car wheelbase in 1937 was also 112 1/4".
:) wink :grin:
My Engineering data book shows the overall frame length as 160 15/16 inches. This book has a lot of info in it. Try to get a copy. There is a place you can call to get a copy free but I can't find the number right now. If I run across it I will post it here.
I think I have figured out how to measure this. I was told that there is a hole in the frame that is the center line on the front? I have what used to be a bump stop on my frame in the rear this should be center line for rear? Has any one ever seen any frame specs. like for a frame machine? I realy want to try to use the frame I have. due to cost and then shipping.
