I have a 1933 1 1/2 ton truck and I am replacing all the wood. The cab was pretty straight forward but now I am working on the doors. Is there a trick to getting to all the old wood out? It appears that I either need to drill out some rivets or break some spot welds that hold the door skin to the metal frame.
On the hinge side of the door, through the wood piece at the bottom, there are 4 carriage bolts thru the wood onto a bracket. The bracket appears to be riveted onto the hinge pillar. The nuts for the carriage bolts are between the skin of the door and the bracket and there appears to be no way to get to them.
On the hinge side in the middle of the door, there are some brackets with the same situation as above.
The sheet metal at the top of the door, on the hinge side, also seems to be trapped.
Thanks for any help you can offer.
