#96586 03/03/07 11:07 AM
tcgood Offline OP
Hello again,
I have a 1926 Chevy Coupe. I want to change all of the lubrication in the engine, transmission and differential. What is your recommendations.
Thanks,
Terry
tcgood #96587 03/03/07 11:22 AM
I use either 30W or 10W30 in engines. Yes it has detergent. Since I am in the warm South a higher viscosity works for me. For cooler areas 20W or 10W30 would be a better choice. I use 90-140W or 600 weight oil in transmissions and rear ends. The recommended "heavy oil" specified is 600 or the modern 160W grade.
Chipper #96619 03/03/07 05:46 PM
With the removal of zinc (an anti scuff agent that keeps flat tappets from getting chewed up) truck 15-40, which still has plenty of zinc in it is a better choice. Four cylinder Chevy cams wear out far too quickly without giving them an excuse.
Herb Kephart
When I works,I works. When I stops to think,I goes to sleep
tcgood #96660 03/04/07 09:02 AM
Keep in mind that your engine for the most part is splash lubricated. The heavier oils won't get splashed around as well as a lighter 5W30 or 10W30.
Steve
HerbK #96667 03/04/07 11:13 AM
I am not sure that all the heavy duty oils still have the same zinc levels as in the past. I recently purchased some Rotella T that was labeled as SM which is the same designation as the low or no zinc oils.
Splash lubrication is critical in all the pre-WWII Chevrolet engines so use of high viscosity oils are a recipe for disaster.
