#95469 02/11/07 09:35 PM
big D Offline OP
How much clearance should there be on the bearing caps to crank, and connecting rod ends an well. Thanks for your help.
big D #95472 02/11/07 10:19 PM
Main clearance is 0.001" to 0.0025". If larger than 0.003" at the center will produce a low speed thump and rear an oil leak.
Chipper #95476 02/11/07 10:33 PM
big D Offline OP
Thanks Chipper. What about connecting rod clearance. Is it the same as the main's
big D #95477 02/11/07 10:50 PM
Rods can be a tad tighter but no less than 0.001". Best way to check clearance is to take out shims until it just locks on the crank. Then add one shim on the camshaft side. Roll to see if there are any tight spots. If none then go to the next one.
Chipper #95480 02/11/07 11:11 PM
big D Offline OP
Thanks again Chipper. Don't know what I would do with out you guys.I sure appreciate all the help I have been getting here.
Chipper #110724 11/17/07 12:33 AM
Chipper,
Can I ignore the third party repair manuals the tell me that I must remove an equal number of shims from both sides of the connection rods?
So far on my rebuild I have adjusted almost all of the connecting rods on this '32 194 to a "snap fit" using an equal number of shims on both sides of the connecting rod. However, there is one connecting rod I can still move by hand.
32confederation (Canadian, eh!)
I have never had a problem with using an uneven number of shims. That way you can effectively take 0.001" at a time. Elsewise you are limited to 0.002" increments. Just remember to take the extra shim from the camshaft side.
