#94570 01/28/07 05:23 PM
OK
What is the trick to removeing the rear springs on a 35 Standard?
Gary
To remove the springs first remove the U bolt nuts and plate below the springs.Remove the front "thru" bolt nut and bolt.Remove bolt passing thru rear shackle, shackle will then come appart.Spring will be free of the axle and frame.
On what step of this operation did you get hung up on?
If I understand correctly the bolt (number 2) in the drawing below acts as a clamp to hold two sides of the shackel together
Gary
[Linked Image from barnettcorporation.com]
Correct,remove it and the side plates will fall off (remove grease fittings)
Before you undo anything support the chassis imeediately forward of the rear springs so that the wheels are at least just clear of the ground. I would undo the Ubolts first then rear shackleswhile supporting the spring. I would hate to hear that the car had fallen on you.
Not to worry! The car is supported by 4 6-ton stands.
It seems the procedure to remove the front of the rear springs would be to remove the grease fitting and then it looks to be through bolted with no nut on the back-side
Gary
Your correct.I was thinking of the Masters that had a rubber encased metal bushing pressed into the spring and a just a big bolt going thru it.....and no grease fitting.
My standard has grease fittings set into the head end of the bolt
for the front mount on the rear spring.
I have tried to loosen the bolts but there isnt much room, I'm going to apply some penetrating oil and see how that works out
Gary
On the front of the spring the bolt doesnt turn, undo the nut then the bolt will slip out. There is a cut away int he bolt head that fits upto a locating lug on the hanger to keep the grease hole in the correct position.
TonyW
Undo what nut??
The front hanger for my rear springs seems to have a 4inch bolt that goes through one side of the hanger,the spring and then the other side of the hanger. In the center of the head of the bolt is a grease fitting and the bolt only protrudes 1/16" throught the other side of the hanger, there is no nut.
Thanks, Gary
That has to be rare. Any possibility of a picture?
Agrin devil
I figured it out!
Under all of the 70 year old grease and crud there was a lock down to keep the shackle bolt from turning. Once I removed the lock the bolt came out quite easily.
Now I need to find new shackles for both rear springs.
Any Ideas?????
Gary
35Chevy
If you removed the plate that sits against the cut away in the shackle pin head I would vigorously recommend that you refit it as it stops the pin rotating and reducing the greasability of the shackle causing premature wear.
Tonyw
I will be putting the locking plate back when I install the new springs.
When I removed the bolt it was badly worn, I checked all of the various suppliers and it's not an item anyone has had for years.
I went to my local truck parts store and was able to find some 9/16-18 grade-8 bolts. They are at the machine shop being drilled and having grease fittings installed.
When your car is 72 years old I guess there are just some parts you have to have made.
Gary
Gary
After I replied last night I read your other posting further down chat, when i looked in my Filling Station catalogue I realised the 35 have a different setup to my 38 so basically I gave you incorrect information.
The Filling Station lists pins bushes and lock tabs for the 35 at what I consider a reasonable price.
