Hi Cleon,
The rear wheel felloes with the extra 3 rim bolt holes,were for a rare optional set of extra wide tyre rims.My truck has the hollow cast steel spoke wheels front and rear,and even the fronts have the extra three rim bolts in them.
These rims used the normal 6 rim bolts,as well as another three rim bolts & lugs the same as the other six.The rim itself is a different design to the normal truck split rim,in that the tyre is retained by a locking ring that fits into a groove on the outside edge of the rim,very similar to the type of Kelsey Hayes rims,F**D Model "T" trucks used.
With this type of rim,if you got a flat,if you could prise the locking ring out,you could change a flat without removing the entire rim,making life a bit easier.
In the 24 1/2 years I've owned my '28 LP truck,I've only ever seen one complete pair of these rims,and another pair that would make up at least one rim,as the other was too rusty.
With the standard rims you can run 6.50 X 20" tyres normally,but the extra wide rim would let you run up to at least 7.00 X 20",or 7.50 X 20" tyres even possibly 8.00 X 20" tyres.
Hope this helps.
