Posts: 377 |
Here is one on ebay for you guys looking for one:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=008&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=180074965965&rd=1,1
Doug
Looks like a good one. Only part missing is the spacer. Most people would not know that a spacer was supplied with the lock.
Posts: 113 |
Was the same lock used on the 1932 side mount tires.
No!  :grin:
Posts: 102 |
Chipper, What is the spacer you are refering to? Is it something that goes on the threaded rod other than the Special nut that the lock engages with? Thanks.
Johnmc, Yes the spacer goes between the lower nut (next to the top side of the fender) on the verticle rod and the special tapered nut with the slot for the lock. It sets the space correctly so the lock "foot" is properly positioned just above the rim.
Posts: 377 |
Chipper, Would I be wrong in saying the spacer is used with the tire with wire wheels while the spacer isn't necessary with the tires with demountable rims used with the disc and wooden wheels?
Doug
Doug, Sorry to write that you are probably wrong. Since the spacer positions the "foot" just above the inside of the rim it would not make any difference in the location of the foot whether the rim was on a wire wheel or just a rim as used on a disc or wood wheel.
Posts: 377 |
Chipper, I found the installation instructions for the locks. One part reads: IMPORTANT When installing lock in connection with wire wheels the spacer furnished should be installed under locking nut as shown. Spacer to be discarded when lock is used with rim and tire only.
If I can get this scanned I will send it to Bill Barker if he would like to put it on the 1931 Site.
Doug
Drat, dem black feathers don't taste 2 gud. I sure would appreciate a copy of those instructions so I don't make that mistake again.
Posts: 102 |
Doug Did you get a chance to scan the instructions? I would love to see a picture of a spacer to see if I can make one. Thank you.
Posts: 377 |
I can email an old photo of the instructions if you give me your email address.
Doug
Posts: 377 |
John, I emailed you both the instructions for mounting and also a picture of the lock, lock nut and spacer with dimensions to you. Did you get them? If not give me your email address again in case I sent them to the wrong address.
Doug
Posts: 3,008 Likes: 1
Posts: 3,008 Likes: 1 |
The spacer is 11/16 long, 15/16 OD, 9/16 ID.
Joined VCCA June 1, 1961
Posts: 102 |
Doug, I got the pictures and they are very helpful. Thank you very much. John Mc
