Radiator in my 34 half ton pickup has developed a leak. What is the "easiest" way to remove the radiator? Do I have to basically take the hood, etc. off and remove the radiator and shell, etc, and then separate the radiator? Or, can I get at it from "under the hood, and take it out separately?"
Thanks. wjb
No easy way.The shell must be removed.
Yep, you pretty much have to take apart the front half of the truck.....
Chevy Guru
Thanks guys. I was afraid of that. wjb
I was able to leave my hood in place when I removed the radiator and shell from my 33 sedan. I was working alone and found it easier to do it that way. I removed the hoses and propped the hood with a piece of wood from the top of the valve cover, then unbolted and removed the shell.
Thanks, I appreciate that suggestion. wjb
I have had the radiator in and out of my 35 std twice recently. After the radiator was rebuilt with the top tank from one unit and core from another I could not get the fill opening to clear the radiator shell for cap clearance. Hence the in and out. Rather than go back to the shop I decided to file the mounting holes to the shell framing to elongate the holes by about 1/4 inch. Fits ok now. If you have major repairs done, double check the radiator to shell fit before reinstalling. I went the hood and shell removal route and only had to get help with the hood so I would not scratch things too badly.
Looserocker---I will certainly keep that in mind. Thanx. wjb
