Posts: 316 |
Need the measurements for the rear door on the 32 sedan delivery. :confused:
See the USA in a Vintage Chevrolet
Which '32 sedan delivery....the early or the late? :confused: :confused:
Posts: 980 |
The early body has a sunshade panel, the later one does not. The early body has job number 31570. I can get you some measurements from a 1933 Sedan Delivery which is like the late '32.
If you have old Chevrolets, other old Chevrolets will find out where you live.
Posts: 3,163 |
I can give you measurments if it's a job # 31570. I have one of those. joe
Posts: 316 |
Thank's for the response will post the job # just as soon as I can get to the car again. Will check the engine serial # we should be able to figure out if it is an early or late from there, but if I remember correctly it has the visor. Still running today.
