Posts: 86 |
After having tried in the Parts Wanted section I have turned to this Forum. Can anyone tell me where I can get a rear driver side brake adjuster assembly. The unit where the rod connects and also where brake adjustments are done. Are there any reproductions? I can no longer adjust the brakes. Turning the screw will not make any adjustment it appears to be stripped inside the unit.
Jerry Million
Posts: 2,299 Likes: 8
Posts: 2,299 Likes: 8 |
Jerry, I can probably help you with that. Are both sides the same?
Posts: 86 |
I'm unsure if they are the same. Maybe JYD or someone will tell us.
Jerry Million
Yes, both rear service brake levers are the same from 1930 thru 1932.  :cool2:
Posts: 86 |
Thanks JYD. Chevy b I have sent you a email about adjusters.
Jerry Million
