Posts: 1,178 |
Posts: 988 |
Nobody is that I know of! It is an easy panel to frabricate on your own. Do you have a picture of the damaged area? I might be able to help.
Posts: 1,178 |
Posts: 988 |
How bad are your doors? If you can email pictures that will help. Is the wood in the doors ok? Most of the rust outs occur where the wood has started to rot and has absorbed moisture and then holds it against the bare steel.
