Posts: 2,157 |
thanks, macky...  epi
Posts: 2,157 |
Posts: 1,290 |
Kepi, the by-laws look good to me also. You have my approval.
Posts: 2,157 |
thanks, sal...  epi
Posts: 980 |
How do I get a membership application?
If you have old Chevrolets, other old Chevrolets will find out where you live.
Kepi, Looks good except for a couple of suggestions of changes that might be made. I sent them to you by return email.
Posts: 2,157 |
chip, thanks...I'll look them over...  epi
Posts: 1,411 Likes: 7
Posts: 1,411 Likes: 7 |
Guys: Look good to me. Thanks for the hard work. 37Blue
Posts: 210 |
Kepi, Got the draft, looks very good, thanks
Posts: 2,433 |
Kepi,
The draft bylaws look good to me. I assume they are taken from an "example" set forth by the VCCA, or are similar to other "conventional" Chapters. In any case they look like they will probably work ok.
Thanks for all the work putting them together.
Ken
ken48 VCCA 42589
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
you get an attta-boy kepi. mike
Posts: 2,157 |
thanks, guys... ken48, yes, it was modeled after vcca boilerplate, with adjustments as appropriate to what we're trying to establish...  epi
Posts: 194 |
Kepi I received the draft and it looks good to me. Thanks for all of your hard work. Rich James
Rich James
Posts: 2,157 |
glad you got it okay, rich...  epi
Posts: 1,866 |
Mine says,"Can't find ACROREAD.EXE." and don't know what it means when it says "Type in the excutable to be used instead" so will have one of the kids install ACROREAD for me and then I should be able to pull it up I hope. To bad all 10 left home already.  On the 2nd thought-------
Posts: 2,157 |
jerrygolf, sorry it didn't open correctly...please let me know if you continue to have problems opening the file...perhaps I can send it to you in another format that you can read...  epi
Posts: 959 |
Hay Kepi,
Your hard work looks great!!
Posts: 1,866 |
Kepi, I'm sure my daughter can get it to work but it might take a week but that's OK. Thank's again. jerrygolf
Posts: 11,162 |
Jerry,any time you see a file with the extension PDF that means you will need Acrobat Reader installed on the computer or a comparable program, many files will ask if you have Acrobat reader and if not you can download a free copy.Acrobat Reader is a product of Adobe software. I always try to send files to people like myself that have Microsoft Windows in a Mirosoft Word format because most PCs come with Word installed.
Posts: 2,157 |
thanks, bob...  epi
Posts: 2,157 |
jerry, just sent you an e-mail...  epi
Posts: 238 |
Kepi, Got the draft, looks real good! Thanks for all the time and energy you put into it. :) 1929 Chevrolet: A Six In The Price Range Of A Four!
Capt. Harley
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
Kepi I reiterate all the above comments you have done real good. I have replied direct but is only a clarification of section 4 B. Is there a set figure for this? Am I to sign and return or is there more to the process before that is to happen. Tony
Posts: 1,866 |
Kepi, Got the draft, it opened, and looks good. Thanks for the extra effort and will install Acrobat Reader. jerrygolf
Posts: 2,157 |
jerrygolf, glad it worked out...  epi
