#8603 04/19/04 11:02 AM
I just finished installing a new radiator core from the FS. The core is looks great I'm glad I didn't use a modern core.
The problem is that while it no longer over heats or boils over the gauge still reads hotter than I thought it would. During normal driving it reads at about the mark where Alcohol boils. If I let it idle for a long time it creeps up past the normal range about half way to hot. I checked the coolant temp with a thermometer and it reads 180 degrees at idle, and about 140 after driving before it heats up.
This is a marked improvement over the old radiator, but I wasn't sure if I still may have a problem.
Any thoughts? :confused:
Jim
#8604 04/19/04 05:37 PM
You don't have a problem!!! Most dudes would kill to have a car run that cool. Your new radiator is doing a great job so leave things alone. yipp laugh laugh laugh
#8605 04/19/04 07:05 PM
Thanks Skip. The new core is Super. The radiator shop I took it to couldn't belive how heavy it was.
Thanks for the help.
chevy
#8606 04/19/04 07:15 PM
Yes, that is a very high quality radiator and it looks like the original honeycomb too! It is well worth spending the money to get a quality radiator like that and one that will do the job. Also, the new honeycomb radiators are far superior to the original radiator core as well, and I don't know why anyone would want to use a 74 year old radiator when they are going to use the car as a driver. laugh laugh laugh laugh
#8607 04/19/04 10:09 PM
I had the same kind of concern a few years ago when I put in the new "Billy Possum" oil pump to replace my old original one. The pressure gauge sometimes pushed hard to the right, and I worried out loud to a friend if that might be a problem of too much pressure. bigl
