#84649 11/06/05 01:45 AM
Today I was driving down the road with a bunch of my friends in my '92 GMC 1 ton and as I was shifting from 1st to 2nd my gas pedal got stuck and it was to the floor!!! The truck started overrevving but had a rev limiter or something so it didn't go over 5 grand thank god! I had to shut the truck off and kick the pedal to get it back up! Thank the lord it was on a back road!
1939 Chevy 1 1/2 ton dually rear wheel pickup
1940 Chevy 1 1/2 ton single rear wheel pickup
1946 Chevy 2 ton cab and chassis
1977 Chevy 3/4 ton camper special 4x4
Obsessed 16yr old Chevy truck nut
#84650 11/06/05 05:06 AM
Hey Bob!!!
Never a dull moment, huh!!!
Glad it worked out OK.
What caused it???
Bill.
#84651 11/06/05 05:09 AM
A friend had similar happen and turning the key off didnt help the first time either, it did act as rev limiter though.
#84652 11/06/05 01:18 PM
I dont know what caused it. Perhaps there was a sticky spot in the linkage somewhere.
#84653 11/21/05 09:36 PM
Did you find the cause of the sticking pedal? If it happened once, it will happen again.
#84654 11/21/05 10:01 PM
Yup!!
I've never met a "problem" yet that went away by itself!!
Bill.
#84655 11/21/05 10:48 PM
I'd call the dealer and find if there is a service bulletin on it. If yours stuck others have likely done it too. Also can check to see if the Feds have anything on it. Don't know the site but recalls and vehicle problems are posted several places on the WWW.
#84656 11/21/05 11:30 PM
You will find that the gas pedal linkage is cable and it is "frayed" at the end. Just replace with new cable..
#84657 11/22/05 03:37 PM
xxx Offline
Same thing happened to me in a Honda back in the '90s....it took off like a shot...scared me to death.
For a lot of cars turning the key off will lock the steering wheel so make sure you turn the key back enough to unlock the wheel; which is what I had to do.
Never could find out why it happened....traded the car (with a warning) to a dealer for a '89 Camaro.
#84658 11/22/05 04:15 PM
Gator
If that Honda scared you, you should try it in a "t" bucket with a blown 454, 4 spd, 5.14 gears.......We never got that seat cover back to the relaxed position....joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
#84659 11/22/05 04:28 PM
xxx Offline
Joe, I think I will pass on trying that...LOL
PS...were there any other problems with the seats that maybe needed a bathroom cleaner? more laughing... bigl bigl bigl bigl
PSS...that experience is why I use a double spring on the throttle now.
#84660 11/22/05 04:43 PM
Aye, that they be. Younger crazier days. a little more stock these days....joe
1968 Z/28 Camaro
1969 SS 396 Camaro
#84661 11/28/05 01:05 AM
sue Offline
man that is scary. ive had that happen once and it was enough. we were test driving a 70 gto judge and the gas pedal stuck and my hubby had to pull into a parking lot and put it in neutral and kick it down. luckily it was ok but needless to say we didnt buy the car.
#84662 11/28/05 02:45 AM
So Sue, what kinda car(s) do you and hubby have now???
:confused: wink :confused:
Bill.
