Posts: 3,163 |
I'm been looking at wheels for my 31 sd & have noticed that where the spokes go into the outter rim, that area is wider on some wheels than others. One measures approx 1-3/4 while the other measures approx 1-7/16. Does anybody know why? Are there i.d. marks on 31 wheels? If so, where might someone find them? thanks, joe
Posts: 3,163 |
yes JYD, That is correct. It is a little taller. You didn't indicate if there are any i.d. marks on them thanks, joe
Posts: 3,163 |
Actually there are two wire wheels for 1930 and three for 1931. One for each year had adjustable spokes and are extremely rare. The JYD is correct that the center depression is narrower for 1930. There were at least two different manufacturers of wire wheels for 1930 and three for 1931. Hence the difference in markings and dimensions.
Posts: 566 |
You can contact an man in Foxfield, Colorado, his name is Don Rossi ph#303-690-5180 e-mail mrrchev@wmconnect.com
Four doors are great
Hoppy
Posts: 99 |
Did the 31 pu truck have one wheel size or used both?
The '31 pickup used disc wheels and not wire. They are the same as 1930 disc wheels.
