Posts: 4 |
Hello, I am detailing an original 1930 2 door sedan engine. I would like to know what the original color was. any help would be great. Thanks.
kajones
Posts: 97 |
Kajun, If you go to the top of this page and click on the search tab and enter your search words you will find many past posts with the info on your engine color. Good luck. hope this helps.
Posts: 3,542 |
Boy, will you find some threads....many threads...everything you ever wanted to know about what to paint what is there.
Posts: 3,542 |
JYD, I know that shade of engine blue-gray offered (well advertized too) from that well known company is wrong for '32's, is it "OK" for '30????
In fact the dark blue-gray color is correct for 1929 - 1950 engines. If I remember correctly it is also is correct for the 1951-3 standard transmission engines also but I have slept several times since I last looked it up.
The 1951-52 Power Glides were also gray.
