Posts: 108 |
Hello USA!
There is no metal glass rim(Backlight moulding) in my coach 1931. My question is:Is there supposed to be a metal moulding like the one on the side windows or should there be something else?
Bengt.
Posts: 45 |
Hi Bengt My 31 Coach had a wooden ring covered in mohair to match the upholstery that was nailed in place all around the inside diameter. No metal ring.
1931 Coach
Posts: 108 |
Thanks for ansver Dana.
In original shall it be metal ring?
Posts: 156 |
Mine is the same too. It is wood covered with faberic
Posts: 108 |
Thanks you all!
A friend of mine who has two 1931,one coach and one sedan de luxe.The coach have steel garnish moulding.How can I identify when my car is made. The frame Nr XSCO 1751 The engine Nr 2438767 Are there someone who makes metal garnish mouldings for rear windows in USA. Bengt
Posts: 57 |
I don't know about the metal garnish molding, but I have a new pre-bent oak trim piece if you need it. I bought it for a 30 4 door I was restoring a few years ago and never used it. I got it from Grady Cox.
What ever happened to Grady anyway. I had seen his ads in the G & D for years, bought a few things from him then gone??
Posts: 57 |
OHHH! His wife said he would be gone for a while. I guess that's what she meant.
Posts: 11,162 |
Yes he did, He posted an add in G&D explaining why he wouldn't be doing business as usual, He blamed his incarceration as being related to viewing a web site!(NOT THIS ONE) Haven't heard anything since........
Posts: 57 |
I must have missed his ad.
Thanks.
Posts: 980 |
I heard that it was a fraudulent prosecution, I had no trouble believing that.
If you have old Chevrolets, other old Chevrolets will find out where you live.
Posts: 11,162 |
Pumpkinj, Actually it was a letter to the Editors.
Believe what you like, Texas courts usually give the defendant and the people a little justice......So much for this particular affair for me, I wasn't there in the courtroom.
Posts: 57 |
I don't know about what happened. I always had good dealings with Grady.
Anyway thanks for the info.
