Posts: 216 |
I have an original inspection sticker from '53 on the windshield of my '39 and would like to keep it on, but (like the idiot I am) dropped the windshield and broke it. The part with the sticker is still intact, luckily. How can I remove the sticker and save it?
1939 Chevy 1 1/2 ton dually rear wheel pickup 1940 Chevy 1 1/2 ton single rear wheel pickup 1946 Chevy 2 ton cab and chassis 1977 Chevy 3/4 ton camper special 4x4 Obsessed 16yr old Chevy truck nut
Posts: 765 |
You might have better luck cutting the glass around the sticker and keeping the glass section. A glass shop could help you with this I'm sure.
Member 45+ years, been around since the beginning !
Posts: 216 |
No, I want to put it on the truck again. I need to transfer it from the old windshield to the new one.
Posts: 11,162 |
Since it is from 1953 and expired check with the State MV department to see if you will get in trouble for displaying an expired inspection. if not maybe you could color photocopy the old one on something that would hold up on the windshield. In Texas our cars with Antique tags don't require an annual inspection sticker.
Posts: 201 |
Hi Bob,
When I was in my late teens, 1976, we lived in NJ. I have seen where inspection stickers were retrieved from cars in the junk yard by pressing a wet sponge against the sticker for about ten minutes. Then carefully using a flat razor, peel the sticker away from the window. Also saw this done in Louisiana in the early 80s. My guess is these stickers were pretty fresh and had not been plastered to glass for 50 years.
Posts: 326 |
Penna inspection stickers of that vintage used a water based glue and many fell off the windshield before the six month period was up.Its rare that it is still on there,take good care of it.
woody
Posts: 216 |
I dont want to reproduce it, that's cheating. I want the original one on the truck. I heard of using an iron to steam it off, but I dont want to screw it up. Antiques up here only need inspected once, and I have seen other cars with old inspection stickers on them.
Posts: 2,157 |
hey dog, quote: ""Cheating" is when you are playing poker and you pull an Ace out of your sleeve to fill out an inside straight." if you use an ace to fill an inside straight, that not "cheating"...that's "bad cheating"...  epi
Posts: 2,157 |
oh sure...now you've edited your post...that's cheating!..  epi
Posts: 2,157 |
doggy, got it...is poker some kinda card game?..  epi
Beats me.......... most dogs don't play poker. :eek: :eek: :eek:
Posts: 2,157 |
some do...I've seen pictures of them...  epi
Posts: 2,157 |
dog, I think we're done with bob's decal...one that old isn't likely to survive removal AND reinstallation...that'd be two miracles...I think a repro would be the best option... and no need to get personal...I think I AM related to those other dogs...  epi
Posts: 216 |
Thanks guys, maybe I'll just cut the glass to save the sticker and put it in my room or something.
Posts: 399 Likes: 1
Posts: 399 Likes: 1 |
Keppi Doodle?
Posts: 2,157 |
novasscott, actually, it's kepi doodle...  epi
I know your brother Yankee
