Posts: 3,542 |
Does anyone have a special way to clean dirt dobber or dabber "concrete" out of bolt & screw holes?
Posts: 3,008 Likes: 1
Posts: 3,008 Likes: 1 |
Run a tap into the hole, remove the tap, and then blow the dust out or use your shop vac and suck the dust out. You may need a # 3 tap to get all the way to the bottom of the threads.
Back Roads
Joined VCCA June 1, 1961
Posts: 194 |
A set of taps...light oil (3-In-1, etc.)...Walkman..."The Redheaded Stranger"...patience :eek:
1924 Superior "F" Touring Car
Posts: 11,162 |
Improvise! A pressure washer works for me, then squirt in some WD-40 or PB Blaster and blow out with compressed air. I also use a small screwdriver, from a set like you can buy at Radio Shack Tom Is "The Redheaded Stranger" not available on 8 track?
