cabr40 Offline OP
I am rebuilding a 283 which came with a Rochester 4 barrel.
1.) What are the pros and cons of Rochester vs Carter?
2.) Are the intake manifolds the same?
3.) In production when did they use either?
4.) Are Rochester rebuild kits available and where?
Thanks,
cabr40
RonVan
Support The VCCA!
See my reply to the other post...First I can't get a reply thru and when it does go thru its in triplicate....well better than nothing
