Posts: 132 |
I need to mount a two post radio antenna on a 39 chev but don't know where to drill.
I can Email you the info-need your address....chevgene@msn.com
Posts: 132 |
please send to ouchicarumba@telus.net (no it's not my name just an alias my 6 year old made up).
Thanks, Mike
Posts: 132 |
Chevgene, your info tells me a lot about the antenna and how to drill & connect it but doesn't tell me where to drill. It refers to a template that is not included.
Sorry about that detail......
I checked mine.The antenna was on the car when I purchased it but the location agrees with the factory pictures.
The center of the top hole would be 3 1/2" below the bottom of the belt moulding.The bottom hole center is 6" below that.The hole centers are 2" ahead of the front door edge - measured from the cowl edge - not the door edge.(front of gap). The 1939 antenna ball is red.
Posts: 132 |
Perfect, with your dimensions I can get the antenna in the stock location. My 39' didn't come with a radio but with your info it will now look original. Thanks again for all your help. Mike
