#77114 05/21/05 07:21 PM
RalphL Offline OP
Anyone have any problems when using an accessory heater shut-off valve? I was thinking about installing one on my 39 Mster Dlx to keep it cooler inside the car in the summer. cool However, a friend told me my engine might overheat quicker. :( Any advise?
Support The VCCA!
#77115 05/21/05 07:30 PM
I have one on my 47, and have had no problems.
As far as your car overheating, there really is not that much hose from the heater to the engine so any cooling advantage would be very slight.
"Heaven is Driving my 47"
With that "GOOD GULF" gasoline.
http://www.gulfhistory.org/?
#77116 05/21/05 09:56 PM
While crossing Nebraska one year with 105 degree heat (at 65 MPH with a 4.22 rear end)(with four other '37's and '38's with the same rear end following)I did turn on the heater blower from time to time and the temp. needle would move down a hair.....usually run my heater shut off valve in the closed position in the summer.As fleetmas47 said the difference would be slight and only temporary.+it never gets that hot where you live wink
#77117 05/22/05 12:56 AM
...Or just take one hose off and connect the shortest one hose to the in and out of the engine.
#77118 07/29/05 01:16 PM
Waht does the accesory heater shutoff valve look like for 39'? Anyone have a picture? I have this brass valve in the shape of a Y screwed into my water pump with a seized dumb little wing nut style screw on the top. Is this what you guys are talking about?
#77119 07/29/05 01:41 PM
Yes-and no.Sounds as if you have a 1940 and up valve.The 1939 and prior does not have the winged screw type.The coolant flow is shut off by loosening a lock nut and then turning a hex bolt in the center of the lock nut.
If you would have listed your Email address in your profile I would have sent you a picture :
#77120 08/05/05 05:37 PM
you have a 1940 and up onthere now.. had one on my 40 for 45 years never a problem .kozy 2772
Tom Koziol
