Posts: 1,178 |
After the steering wheel and all parts attached to the column are removed-remove the metal splash guard around the gear.Unbolt from frame-rotate gear - raise and bring forward up into the engine compartment and go forward.Not necessary to remove from under car.
Perhaps its radio controlled steering???
Posts: 11,162 |
After you have the steering wheel off and the column bare and unbolted from the dash the rest of the job is easy.
Posts: 1,178 |
Sorry about the placement of the post, must have let the old mouse slip.
