Posts: 959 |
Is there an adapter so one can use a newer antenna connector with an older style 1940 radio?
Thanks,
Posts: 291 |
BigBob, Have you tried Radio Shack?
Dan.
Together we can do anything. The impossible just takes longer.
Posts: 959 |
Thanks Dan Never thought they would have one, but I will definitely check today. 73,
Posts: 959 |
Again, Antique Mechanic came through and solved the problem with a replacement modern socket!!
Posts: 3,542 |
Posts: 959 |
Antique Mechanic sent me a new socket to replace the old one with. Adapters are like hen's teeth!
