Posts: 959 |
Was the 1940 backup lamp mounted on a bracket or by drilling a hole through the body? Thanks,
Posts: 2,037 Likes: 5
Posts: 2,037 Likes: 5 |
The 1940 Chevrolet back-up light was mounted on the body by drilling 1 hole thru the body. The wire for the back-up light goes thru the center of the mounting bolt. I can send you digital photo of what an original one looks like that is mounted on my 1940 business coupe. There is a template for determining the correct mounting position. In the Midwest there was a gentleman from the Fort Wayne, Indiana area who reworked motorcycle running lights into a reproduction 1940 Chevy back-up lamp. I had owned one of them and I have seen a number of these over the years for sale at Hershey Swap Meet. Here lately, the supply has mostly dried up. Be aware of paying top dollar for a reproduction light. I have an original 1940 Guide back-up light to trade for a 1940 center arm rest or?
Posts: 959 |
Thanks, Toolman!
I don't think I have the heart to drill a hole in Sweetie Pie after filling so many that Mrs. Williams's husband drilled over the years. I'd love to have the digital picture that you offered. I will keep a look out for that elusive arm rest that you are looking for! :)
Thanks,
Posts: 167 |
That same light was used on Harley Davidson bikes, Allis Chalmers tractors (as a tiallamp) and hundreds of other vehicles. They pop up at swap meets and a fellow from Des Moines IA. sells them. I used to make the bezel for the lens for him. It shuoldn't be too hard to come up with one...
Any man that thinks he is too old to learn something new probably always was
Posts: 959 |
Thanks, Coley!
I'm on the hunt, so will hopefully find a nice one. :)
To the best of my knowledge, Guide or a similar manufacturer made small running lights for Harley Davidson that look similar to the 1940 Chevy back-up light unit. The main metal painted body, the chrome door/rim are virtually identical to the 1940 Chevy back-up light. The difference is in 2 areas. The first is the lens, which is available in NORS in glass. The NORS glass lens looks very close to original. The NORS plastic back-up light lens do not look original. However, the main problem with the motorcycle lights is the mounting bolt. In almost all instances that I have seen, the mounting bolt on the motorcycle light is exactly 90 degrees in relationship to the light beam. On the 1940 Chevy back-up lights, the angle is not 90 degrees. The angle is more like 110 degrees. If you were to mount any of these motorcycle lights on a 1940 Chevy in the correct mounting position, the back-up light would shine down onto the rear bumper, instead of backwards.
