Ok, Donald here it is. It only took 8 hours of research so far.
Starting Cranks for four cylinder and early six-cylinder era Chevrolets.
The following is preliminary and to be considered a draft document. It is based on research of original Chevrolet and General Motors literature by the author. It is not extensive as all available literature has not been searched and other references have not been sought. Comments, corrections or other assistance to make this more accurate is welcomed.
The earliest Chevrolets used a multi-piece starting crank assembly. They consisted of a shaft and a lever/handle combination attached 90 degrees to the shaft. At least four different starting cranks of this type were used as four part numbers were found. Additional research is required to better understand these assemblies.
By 1920 a starting crank, part number 43419 was available. It is illustrated in several parts books as a rod type with two greater than 90-degree bends (estimated to be approximately 105 degrees). One end has a pin through the end that fits slots in the engine crank pulley and a rotatable sleeve on the other end.
Part number 344442 is listed in a General Motors Products of Canada, Ltd., Oshawa, Ontario parts list for Superior, Series “K”. Nothing else is known of this starting crank.
Part number 43419 is listed in two parts books published by General Motors (Aust.) Pty., Ltd. as correct for Capital Series AA passenger and commercial and LM truck models. U.S. published books effective January 1, 1927 and later list part number 334271 for the same models. (The number change is thought to be due to the transition from a five to a six-digit part numbering system and not an actual difference in the part.)
The February 1, 1928 Master Parts Price List, lists 334271 for F,FA,FB,T,G,490,Sup.,U,C (1916-1927) and ) part number 352768 for the National (Series AB). The January 1, 1929 and later Four Cylinder parts books list the later number for all of these models.
The 1929-30 Chevrolet six-cylinder passenger cars (AC, AD) required a longer starting crank to reach through the front apron. It is part number 355441. Commercial ½ ton (AC, AD) and 1½ ton vehicles (LQ,LR,LS) used part number 352768. The same part number (352768) is listed in all parts books checked (1931-1945) for AE, B, CB, LT, M, N, O series (1931-2 passenger, ½ ton, 1½ ton and 1933 Commercial ( ½ ton, 1½ ton).
The Master Parts Price List, For Six Cylinder Models, 1929-1942, effective April 2, 1945 (an excellent book to own) has the following listings. Year Model Part Part List Name Number Price 1929-30 PASS plain end (21 7/8 overall) 355441 .75 1929-33 ALL (exc. CA, CC-1/2 ton on AC, AD) plain end (18 1/2 overall) 352768 .75 1933 CA ¾ in. socket end (18 overall) 370853 .75 1933 CC ¾ in. socket end (16 1/8 overall) 473818 .75 1934-35 DA,DC,EC ¾ in. socket end (22 1/2 overall) 374491 .75 1934-36 DB,EB,FB ¾ in. socket end (20 1/2 overall) 373413 .75 1934-36 P,Q,R 7/8 in. socket end (27 1/2 overall) 373557 .75 1935-36 EA,ED,FA,FC,FD ¾ in. socket end (21 1/2 overall) 475564 .75 1937-42 ALL (exc. JA,JB,KA,KB,KH) plain end (33 1/8 overall) 3661378 .75 1939-40 JA,JB,KA,KB,KH plain end (31 5/8 overall) 350689 .75
This is the only piece of Chevrolet literature found that gives the dimensions for the starting cranks. It also lists the type of handle end.
The author is aware (has a copy compliments of Ray Lemasters) of a “General Sales Department, Service Division” three page letter type document entitled “1932 CHEVROLET SERIES “BA” PASSENGER CAR S.U.P. SPECIFICATIONS” that contradicts some of the above information. The document has a “Issued:- November 13, 1931.” at the bottom of each page. Apparently the document is intended for export vehicles as it lists “2 Passenger Sport Roadster (With Dickey Seat)”, “2 Passenger Sport Coupe … Five Windows (With Dickey Seat)” and “2 Passenger Standard Cabriolet (With Dickey Seat)”. “The Dickey Seat is located in rear deck and accommodates two additional passengers.” Among the tools listed at the end of the document is “Combination Starting Crank and Wheel Nut Wrench”.
Beginning with the August 1, 1929 and continuing through the previously referenced 1945 edition of the 29-42 Master Parts book is the following listing: Wrench, Wire Wheel Hub and Rim Bolt Nut part number 348905. The application listed is 1929-33.
My understanding is that the tools were not actually placed into the tool compartment on the production line but were installed by the dealers. Evidence for that is the 1930 filmstrip “Check and Double Check” and the 1931 filmstrip “Double Check”. If Chevrolet supplied starting cranks to dealers with the lug nut socket on the end why did they continue to list, apparently purchase and supply starting cranks without the socket ends up to at least 1945? Why would they also list and supply the separate Wire Wheel Hub nut wrench.? Why would they continue to list the 1933 Master starting crank with the lug nut socket for only that model? To date the preponderance of evidence from Chevrolet and General Motors literature supports 1933 Master as the first starting crank with the socket end.
Let the vegetables or fruits (tomatoes) fly!!!
Glad to see that all that info is compatable with the tools in my original 33 Eagle. Too late after all these years to go hunt up something to make it correct. No socket end on mine.
Hey Chipper Dipper: Great job on the research! You did a lot of work on this issue, and it probably cut deeply into your bugle playing time as well. At any rate, we now have in detail everything there is to know about starting cranks up through 1940. That is great information to use as reference for the history of Chevrolet starting cranks. If we go by original Chevrolet literature (which I have always totally supported as the basis for all Chevrolet research) then it does, in fact, appear that the first year for a starting crank with the socket on the end was indeed 1933. Now, the mystery arises as to where the few totally all original 1932 Chevrolets that are still floating around got their hand cranks with the socket end? Again, thanks for taking the time to do the research, and I think that it should now solve the question and the problem. This information also needs to find it's way into the judging handbook if it isn't already there.
By the way, do you have any theories as to why the 1932 export models would have a starting crank with the socket end and the domestic models did not?
Now, does anyone have a 1932 (1933) socket end starting crank that they want to trade to Raymondo for his 1933 (1932) starting crank with the plain end? :confused: :confused: :confused: :confused:
Posts: 980 |
If you have old Chevrolets, other old Chevrolets will find out where you live.
Posts: 11,162 |
Well Chipper and JYD, also Ray and Donald, It don't look like someone was right and everyone was wrong, Some dealers and customers decided they needed a better tool so they got the socket end model for their two year old cars, My Dad put great store on having a good crank , and a good lugwrench and jack, Even when he bought his last new pick up in 1959, the one before that was a 48, he raized Cain because they no longer had a hand crank and a screw jack, and even went to another dealer to see if he was being lied to. He found that the screw jack was an accessory and made them give him one at no cost. He then went to Western Auto and bought a 4 way lug wrench (which I still have, it has a screwdriver end to pull hubcaps and 3 socket ends.)
I think someone is mis-reading my post. My car is an EAGLE and the non-socket crank is correct and that is what is in the original set of tools. (EAGLE: Manufactured in the first three months of '33) (MASTER: Manufactured after the first three months).
Posts: 11,162 |
Posts: 11,162 |
JYD someone needs to make sense out of this mess You and I haven't been able to!
Posts: 1,281 |
WELL WELL, LET THE TOMATERS FLY, BECAUSE I THINK DIFFERENTLY ABOUT SOME OF THE THINGS SAID??? RAY HAS A ORIGINAL TOOL KIT WITH NO SOCKET ON ONE END? I WOULD BET THAT THERE WAS MANY STARTING CRANKS THAT WAS PUT INTO THE 33 TOOL KITS TO GET RID OF THEM AND SO ALOT OF 33 CHEVYS HAD THEM AND ALOT OF 33 CHEVYS HAD THE SOCKET ON ONE END. ALSO I WOULD BET THAT ALOT OF 1932 CHEVYS THAT WERE NOT EXPORTED ALSO HAD THE TOOL KITS WITH THE SOCKET ON ONE END. I CAN NOT SEE HOW EITHER ONE WOULD BE WRONG, BECAUSE IF A SOCKET END STARTING CRANK WAS PUT INTO A NON EXPORT CAR, THEN THAT WOULD BE CORRECT BECAUSE THAT IS HOW IT WAS DELIVERED TO THE CUSTOMER. LET THE TOMATERS FLY, BUT WATCH OUT FOR THE FRUIT FLYS. :arrow: :arrow: :arrow: :arrow: :arrow: :arrow:
Posts: 11,162 |
Yea, so did I, Donald are you adding some more confusion to the issue? Just because your Model "T" buddies sold you a wore out Model "T" crank for four figures, don't make it right....
Posts: 1,281 |
Raymondo's car has the plain end starting crank because, according to original Chevrolet literature, the early Eagle models did use the starting crank with the plain end. Also, on the starting crank for 1932, we have to go by what the original Chevrolet literature says, not by rumor or what "came in the car when you bought it". Sure....Chevrolet deviated a lot from what they state in their own literature, but that is conjecture at this point, and 70 years down the road we have to use original Chevrolet documentation about what is correct and what is not correct, (especially for judging) even if Chevrolet chose to do differently on their own. If the literature states that the plain starting crank was used in 1932, then when your car is judged you should have a plain starting crank or points will be deducted accordingly........no matter how many '32's around the country have the crank with the socket end. However, if some documentation were to show up indicating that either starting crank was used in 1932, then that would change the issue.
Posts: 1,281 |
Posts: 1,281 |
Maybe.......maybe not. It all depends upon what kind of documentation he has on the 1932 starting crank. :confused: :confused:
Posts: 1,281 |
Posts: 1,281 |
I REALLY FIND IT QUITE AMAZING ABOUT JUDGING. I WAS THE ONLY ONE WHO HAD THE TOOLS OUT FOR DISPLAY WHEN MY CAR WAS JUDGED AND NO ONE EVEN LOOKED AT THEM, LET ALONE NO ONE ELSE EVEN SHOWED THEIR TOOLS???? :confused: :confused: :confused: :confused: :confused: :confused: :confused:
Is it possible that the '32's with Dickey seats (rumble seats) for export were equipped with the cranks with the sockets because they were going to countrys that used the metric system and the correct 3/4 size wasn't available???????for removing the wheels.(yes I know 19mm is the same)>>>>>>Also I went and tried to get my nuts off with the crank for my '34 and they wouldn't budge...not enough leverage.So how can I get my nuts off with this thing?????
Chev Nut: I'm not even going to go there because it could turn into an Elvira thing.....big time!!! Ha ha! :eek: :eek: :eek: :eek: :eek: :eek:
Donald! That's part of the problem with the VCCA judging........every one does it differently and that is another reason why fewer and fewer cars are being judged at the Northwest Meets. At any rate, there are '32 Chevys out there with the plain type of starting crank. It would be interesting to see what the judges would do if there were two '32 Chevys competing with each other in class and one had the plain crank and the other had the socket crank. :confused: :confused: :confused:
Posts: 1,281 |
I REALLY REALLY DO THINK THAT THIS STARTING CRANK SUBJECT ABOUT WHAT IS RIGHT AND WRONG NEEDS TO GO ALOT FARTHER IN DOCUMENTATION AND TALK WITH ALOT OF PEOPLE WHO MAY HAVE MORE INPUT TO PUT INTO THIS SUBJECT. I THOUGHT THE BADGER PISTON SUBJECT WAS GETTING QUITE INVOLVED, BUT IT DOES NOT HOLD A CANDLE TO THE STARTING CRANK EPISODE? :confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused:
