#7532 01/31/04 12:20 PM
pushrod Offline OP
i am puting the interior in my 31 5 passenger coupe my tech advisor and i cant find a picture or know for sure if the door handle bolts that go into the lock to hold the handle on goes through the door panel or underneath he thinks it goes through with a washer behind the nut the old panels were in a state of disrepair hamton coach ranels did not have a hole for this maybe some one can answer our question pushrod
The bolt goes through a hole in the panel, not a good idea in my opinion because the bolt will slowly get loose and the handle will come off in your hand when you least expect it. It's even more of a problem with the rumble seat handle because the bolt will fall out between the lid and the back of the seat.
If you have old Chevrolets, other old Chevrolets will find out where you live.
Also, I believe that the bolt was nickel plated as well. laugh laugh laugh laugh
Former ChatMaster
ChatMaster - 5,000
Former ChatMaster
ChatMaster - 5,000
Yes, I think mine also went through the panel... it seemed like a poor idea when I saw it....
but if you look at it logically, the upholstery was added to the car... then it probably went down the line and all of the chrome stuff was added at the next station. Handles, bumpers, etc. Sorta makes sense.
I doubt that they added the interior handles piecemeal... probably all at once --- AFTER the upholstery was installed.
Any hoo... yes, tighten it so it doesn't walk out on you.
Bill Barker
(VCCA Member: 9802)
When I purchased my 31 in 1960 it had the original upholstery in it. The bolt went through the upholstery. There is a thin washer under the head of the bolt. In 38 years since restoration I have never had a handle come loose either on the doors or the rumble seat. It is your car and your choice which way you want to do it.
Jim
Joined VCCA June 1, 1961
I have an opportunity to purchase a restorable 31 5 pass coupe. My only problem is that the body panel below the trunk lid is missing. If anyone knows where there is one that I can purchase I would be greatful. I know this isnt helping answer the question but I thought this would be a logical place to ask. Or, does anyone know of a restorable 5 pass coupe for sale? Mel Goddard,Lincoln Ne. 402-421-1230 or Email me at; kgmg3@aol.com thank you
