#74695 03/11/03 10:28 PM
SPANKY Offline OP
Has anyone out there tried the Replacement Step Pads that Jim Carter produces. Spanky Hardy...................Collector Of Fine Old G.M. COE Trucks & Antique Holmes Wreckers
#74696 03/17/03 09:07 PM
SPANKY Offline OP
I guess nobody has tried the repro. COE step pads from Jim Carter Truck Parts. I guess I'll have to try them first, & let you guys know how they fit. Spanky Hardy...........Collector Of Fine Old G.M. COE Trucks & Antique Holmes Wreckers.
#74697 04/16/03 12:58 AM
I am having mine lazer cut from the original paterns in diamond plate stainless steel. My steel guy will keep the program on the lazer cutting software disk if anyone needs these " Better than Original"
step plates, let me know., chevy
#74698 06/07/03 11:39 AM
SPANKY Offline OP
Hey guys, I ordered a set of the Jim Carter COE step pads & they are exact replicas of the originals. They are glued to your existing metal plates. Spanky
#74699 06/08/03 08:30 PM
I would buy a set of J.C's rubber covers in a heartbeat if I had a solid set of steps to bond 'em to. My originals are rotted & over 1/2 the mounting studs are broken off.
I am stickin' with the lazer cut stainless steel diamond plate replacement units on this one.
