Have any of you guys ever had brake systems that "pump-up" as you drive them? My '46 1/2 ton has everything new except the drums and brake lines. The more I drive it the more the brake system pumps up until finally the brakes drag. I have to bleed off the excess brake line (trapped) pressure then the brakes work well until the sytem pumps up again. I suspected the new brake shoe return springs were weak, so I replaced the return springs with another set of new ones. That didn't do anything, so I rebuilt the NOS master cylinder thinking the rubber parts in the MC maybe had gotten bad over the years - again no difference. Everything on this system is new except for the drums and steel brake lines. I mean the wheel cylinders, brake line hoses, brake hardware, wheel bearings and seals, king pins etc.
I adjusted the shoes so I feel them just grip the hub, push the brake pedal to make sure the shoes are centered, them back off the shoes until the wheel spins freely. I did this adj. with the vehicle cool - not warmed up.
When I restored the vehicle I flushed the lines before I installed them - since they were good I didn't see any reason to replace them.
I'm kind of stumped - Any ideas?
Thanks guys!
BTW, have fun in CO, wish I were there!
