#73799 06/19/05 05:56 PM
Joel Offline OP
Were the 1st series 3/4 ton truck axle's cast or forged?
Joel's 48
#73800 06/20/05 02:31 PM
Joel Offline OP
What I intended to ask was, Are FRONT axle's cast or forged?
Joel's 48
#73801 06/20/05 04:50 PM
First series? of 1955? where would one look to tell whether it was cast (iron) or forged (steel)?
#73802 06/26/05 10:28 PM
Joel Offline OP
1948 1st series. I would look for a parting line however, my axle had been ground and sanded very well by someone along the way.
Joel's 48
#73803 06/27/05 10:11 AM
Joel,
Cast iron tends to be brittle, so I doubt (hope !!) that any axle components were NOT castings. Can't imagine farmers driving over ruts & rocks in the fields with a cast iron axle. Forgings are infinitely stonger, based on my (limited) metallurgical knowledge.
I found a definitive reference to the front axle to support this in the 1937 copy of "Chevrolet Engineering Features" which states...."The front axle is a rugged I-beam forging with Reverse Elliott ends." I have not found any other references for later I-beam axles, but I seriously doubt that Chevrolet would have changed the forging method of manufacture.
My 2¢ !!
chevy -Bob
-BowTie Bob
#73804 06/27/05 10:50 AM
All front axles are forged - with no exceptions.
#73805 07/01/05 08:37 PM
Joel Offline OP
Thanks guys for confirming what I hoped was the correct answer.
Joel's 48
#73806 07/21/05 07:03 PM
There is no such thing as a 1948 1st series truck. When you see a reference to 1948 -1955 1st series, the 1st series refers only to the early 55 trucks which shared the "Advance Design" styling with the 47-54 models. Parts which fit 47-53 trucks have no "1st series" tag on their descriptions. Parts for 55-59 trucks often carry a "2nd series" or "12 volt" tag to indicate thier suitability for ony the late 55 trucks.
