Posts: 19 |
Is the 3 speed column shift trans from a 1953 Chev car the exact same transmission in the 3 speed column shift 49-53 Chev trucks?
Bill
Not quite.The rear shaft (main shaft) and rear extension is a different length.Case is also different
Posts: 19 |
Too bad! I had a chance to get a beautiful rebuilt 53 from a car for next to nothing. I need it for my truck.
Bill
Posts: 3,469 Likes: 48
Posts: 3,469 Likes: 48 |
I believe the truck 3-speed is made to be the same length as the 4-speed for easy interchange and simplicity in manufacturing. Gosh, it's been a long time since a manufacturer gave a hoot about either of those features. Mike
Posts: 500 |
If, the rebuilt 1953 Passenger trans is cheap enough buy it and put the guts in your truck transmisssion.
wdoftexas
Posts: 176 |
Yeh, I rebuilt the transmission in my 46 truck with parts from a 53 car. Just make sure all the gears you are going to use match.
VCCA#:45524 1946 3100 Pickup
