Posts: 216 |
Do you have to put any sealer around the edges of freeze plugs before you press them in?
1939 Chevy 1 1/2 ton dually rear wheel pickup 1940 Chevy 1 1/2 ton single rear wheel pickup 1946 Chevy 2 ton cab and chassis 1977 Chevy 3/4 ton camper special 4x4 Obsessed 16yr old Chevy truck nut
You do not "have to" but a thin film of #2 Permatex would do no harm.
Posts: 216 |
Ok thanks. I just punded them in and used some high temp. sealer on them.
If you were smart you would have used brass plugs so they do not rust. Most parts stores carry freeze plugs in convex with no shoulder, convex with a shoulder and brass in both styles. You have to pick and choose on the shoulder/no shoulder ones as they are not interchangeable.
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
agree with ray on the brass freeze plugs, plus you get the added feature in that the moroso brass plugs are not mfgr logo'd as are most aftermarket plugs and originals had no mfgr logos. simply glass bead the exposed surface of the moroso brass plugs before installation so they'll hold engine paint.
