#73356 01/11/05 05:50 PM
xxx Offline OP
While driving my '55 (2nd series) 3600 at night I went over some RR tracks and the headlights went out (they were on bright), I clicked over to dim and they worked fine. So right now I only have dims, whenever I try the brights, nothing just darkness.
Any ideas on how or what went wrong and how it can be fixed??? Everything "looks fine", but...
#73357 01/11/05 06:32 PM
I HAD THAT HAPPEN ON A 68 PICKUP. THE TROULBLE WAS THEN ONE WIRE FELL OFF THE DIMMER SWITCH
1928 NATONAL AB COUPE
#73358 01/11/05 07:43 PM
95% vote for a wire coming loose on the foot dimmer switch. You can access it from under the truck or remove the two screws that attach it to the toe board.
5% vote for loosing the high beam filament in the headlights.
Agrin
#73359 01/11/05 11:22 PM
xxx Offline OP
Thanks, will check the switch tomorrow...opps, maybe Thursday, the 12th is my B-day; older but not wiser...
