#72861 10/16/03 01:29 PM
we'd like to know if the fuel tank straps for the '40 kc 1/2ton are the same as those used through '47?..
we need a replacement pair...
ok epi
#72862 10/16/03 04:06 PM
The fuel tank straps fit 1936-46 cab models (not panels).They are 30 1/2" long.
#72863 10/17/03 12:37 AM
chevgene,
thanks...do you know from what vendor we could land a pair?..
ok epi
#72864 10/17/03 08:17 AM
xxx Offline
Don't know if new replacements are available, but if the straps aren't too weird in shape you might try taking the old ones to a good welder or tinsmith and they might be able to make you a new ones that would look correct and work right. cool
Just a shot in the dark, hope it helps. laugh
croc
#72865 10/17/03 09:52 AM
gator,
thanks for the suggestion...the straps are ok, but the stud ends are corroded...they are threaded studs that have been flattened & riveted to the sheet metal straps...
we could make new ends, but thought someone might know where we could just buy a new pair that are correct to original...
ok epi
#72866 10/17/03 07:36 PM
Kepi, Just keep the tank full and it shouldn't roll around to much.
1940 Chevy 1/2 ton
1940 Chevy 3/4 ton
1940 Chevy 3/4 ton
1949 chevy 3600 daily driver
1947 GMC firetruck
1947 GMC popcorn truck
1957 BMW Isetta
1960 Nash Metropolitan
1958 Morris Minor conv.
1952 MGTD
#72867 10/18/03 01:25 AM
hey brian,
you'll get a kick out of this...that's your tank we put in just yesterday...it went about seven miles before it stalled out for lack of fuel to the carb...we had to walk home, get the k1500, a tow strap, and my wife to get the kc home... :(
we think the fuel pump is full of crud from the old tank...will disassemble it tomorrow to see if this is the case...
we're still hoping to find some good tank straps...
ok epi
#72868 10/23/03 01:47 AM
Kepi, I use a clear 99 cent vw filter inline when I first use a tank that has been just cleaned or sitting for any length of time. Do you have a glass sediment bowl? Are you using any type of filter?
1940 Chevy 1/2 ton
1940 Chevy 3/4 ton
1940 Chevy 3/4 ton
1947 GMC firetruck
1957 BMW Isetta
1952 MGTD
#72869 10/23/03 03:25 PM
brian,
yes, we had a plastic filter in-line...that's what plugged...
we have a nos fuel pump w/glass bowl that we haven't installed until everything in the fuel system is clean and good...for now, it's a new replacement-type fuel pump that the previous owner put in a couple years back...
ok epi
