#72281 03/13/03 01:09 AM
Joel Offline OP
:confused: Passenger side outside door handle won't come off. I have all the screws removed. Suspected corrosion. Applied lots of liquid wrench but it will not :confused: budge. What am I over looking?
Joel's 48
#72282 03/14/03 12:16 AM
#72283 03/14/03 09:58 AM
Sometimes those 47-51 handles can be a pain to get out. The square shaft on the handle that engages into the door latch kinda bonds together. Just keep spraying penetrating oil(PB Blaster)at that part of the latch(you can access it through the hole inside the door)and just keep wiggling and lightly prying on the handle and it should come out.
