Posts: 11 |
I may have the oportunity to aquire a Columbia Overdrive Transmission. Apparently the vehicle that it is in has the shortened torque tube to accomidate it. Has anybody had any experience with these transmissions? I have a 53 3100 that I am trying to restore back to original. Were these transmissions ever intalled at the factory or at the dealership as an option for an AD pickup? I am seriously thinking of putting this in my 53. Can someone shed some light on the pros and the cons of doing this.
Thank you in advance for all of your help and advice.
Rugo Smokem if you gottem, if you haven't gottem, I know where you can gettem.
Smoke em if you got em.
The Columbia over drive was a two speed rear end most commonly installed on Ford products up thru 1948.......I think what you are describing is a Truxtel (may be mispelled) overdrive unit.It was spliced into the torque tube on chevrolets and from what I see available from 1946 and up It was not a chevrolet item.If you purchase one be sure to get all the required parts .The last one I saw installed had linkage to the clutch pedal and some thing on the firewall also if I remember correctly.I have some literature around that describes it so if you need more info. let me know and I'll find it. Have never seen it listed as fittng a 1/2 ton truck so torque tube diameter as well as drive shaft may be different.
