BillT Offline OP
Hey guys
I am attempting to remove the gas tank from my 1951 2 ton flat bed.
AT the bottom of the tank is a T-valve.
There is a hole in the bottom of the cab, however it does not appear large enough in diameter to get the valve through, to remove the tank.
I am assuming the T-valve is brazen on the tank.
Before I get a bigger hammer and damage the T-valve and tank!!!!
Does anyone have any suggestions in getting tank and t-valve removed from the cab without breaking off the t-valve of drilling a biger hole.
The T-Valve does have a nut on the end where the turn piece opens and closes the valve.
I would appreciate any suggestions
Bill T
The valves and fittings are screwed into the tank.
Yep , just unscrew it Bill , mind you don't get a splash of petrol in your face . dance
'40 - 1/2 ton , daily driver.
[Linked Image from i60.tinypic.com]
On my 50 6400 the T-valve just unscrewed.
Make sure you slosh it around after you remove the valve as there may be more fuel held in by the fitting.A 5 gallon bucket worked good under the hole.
Don
Of all the things I've lost in my life,
I MISS MY MIND THE MOST!
