#71694 04/06/02 07:13 PM
I need advice on my 65' C10. I recently bought this truck and I am in the process of doing a frame up restoration. The problem is it has drums on the front but I want to put disc brakes on it. Will the A-arms off a 69' or 70' C10 work on my truck. Any advice would be appreciated. :rolleyes:
JFV
#71695 04/06/02 08:39 PM
I'm confused. You said you were 'restoring' the truck??????????? devil Agrin
#71696 04/06/02 11:13 PM
Should'nt this be under mechanical or trucks? :confused:
#71697 04/07/02 02:25 AM
This isn't trucks? Maybe someone with a Hollander Parts interchange manual will be able to help you. Anyone?
#71698 04/07/02 02:28 AM
If you have a donor from '71 or newer, try to get the whole crossmember. They do bolt on, with some work aligning holes.
'69 or '70 will still have drums.
chevy
1966 C-10 stepside
